serpentine belt blew... not my fault(long)
irjoshy
231
Mar 9, 2003
Elyria, Ohio
ok, my car has been in the shop at a chrysler dealership for a while, they were fixing a few things because of a loud squalling noise coming from the area where the ac compressor is. so it ended up being that they had to replace the ac copressor, the serpentine belt tensioner, and they also replaced a bunch of gaskets due to oil leaks, and they replaced the valve cover. well i thought everything would be fine when i picked the car up. however, when i actually did pick it up, it still made that noise! i was so mad, well the guy said that there was probably something on the belt, like oil or something, and it may need replaced, i'm like wtf, why didnt you replace it in the first place you idiot. so i just leave and take the highway home, and as soon as i hit 2nd gear, BAM no power steering, the car wants to stall, and it starts to overheat. RIght away i knew it was the serpentine belt that blew. needless to say it was very hard for me to get home without blowing a headgasket. all in all it was a bad experience, but i replaced the belt and its ok now. but i think it was the dealers fautl because they should have said that it was in that bad of a condition that it could have blown like that. if anyone has had a similar experience feel free to discuss this
Nothing you can do now. Just deal with it. If it blew as soon as u left, you should have turned around and went back to the dealer and made them fix it
DSMs have more belts than Happy Hour.
Exactually. There is no serpentine belt on your DSM. Unless maybe you did some sort of V6 swap. :confused: Why was it hard to make it home without blowing a headgasket? Your powersteering belt has nothing to dco with the powersteering gasket. Oh, and the dealership raped you. Why would they have to replace your valve cover? I bet they charged you a arm and a leg for that. I thought that the AC compressors were about $400 for our cars. You were having AC work done at the same time? I can't imagine your bill when you left the dealership. The serpentine belt tensioner? What is that? Your timing belt tensioner maybe? :confused: Oil on the belt? I am calling BS on that one. When belts squeal, its usually because they are hard and dry (worn out). All you needed was a $10 powersteering pump belt insted of $2000 worth of labor.
The reason your powersteering cut out and your car overheated is because you powersteering belt broke or came VERY loose. Nevermind, I see what you meant by blowing a head gasket now. You didn't want your engine to overheat and warp the head to blow the head gasket. Gotchya!
That is crazy and sounds like you got bent over at that dealership. Its amazing how easy it is to take advantage of people when it comes to cars.
