BoostedBird
- 192
- May 20, 2002
Milwaukee,
Wisconsin
Hear me out on my theory. I have been trying to figure out why I am not boosting past 7-9PSI. If I disconnect the vacuum line from my MBC to my wastegate, the turbo should spool up to around 20 PSI or so (out of "control" anyways) So then my stock 2G BOV should dump once I hit around 12PSI then right? Since they are notorious for being weak around that point. Hence, the BOV would be acting like my wastegate, right? I tried this and no more PSI past 7! What the hell? So here is what I am looking at:
1. Is my boost gauge junk? I have the plastic line installed but I have checked it for cracks and pinches, nothing. Should I replace it with rubber hose.
2. I KNOW my stock BOV leaks when I do a leak test. Is it possible that it just is really shot and opens at 7PSI? I have a 1G BOV arriving tomorrow for all you flamers out there!
3. I heard a leak by the throttle body but couldn't find it. Didn't seem major but I read about the shaft seals and am ordering some now. Would that amount of leakage cause the low boost?
All I have for mods are filter, intake PVC mod and MBC. I have the MBC disconnected right now trying this new thinking.
Please look this over and let me know what you think. This is really getting old. Car runs fine, just no good boost. NO shaft play on the turbo and no smoke, so that shoudn't be the problem. ANY help is GREATLY appreciated.
