UICP Install now Boost Leak
-GSX-Falcon
199
May 11, 2003
Fargo, North Dakota
I just installed a Dejon Tool UICP and now i think i have a boost leak. I can hear a hiss noise from my TB. I have checked the front gasket that connects to the TB Elbow. I hoped that was the prob so i coated it in RTV and put her back together. STILL hear the stupid leak. So now i think its the TB to Intake gasket...which looks like a bi*** to get to since i have to dissconnect everything from the TB. I was thinking i could buy a small paint brush and try to get in there with some RTV, because from what i can see the gasket is still good, but something is leaking. When i build any boost I sound like an airplane. I have an auto with smaller cams i hear that that will effect my Vac, but here are my readings. In park (or letting off the gas in gear) i sit about 20. In gear at a stand still i sit about 13-14. Any help would be good or any other places i might check around that area. :confused:
try using leakage spray ...Spray that on the places you think are leaking and you will see instantly if there is a leak or not ( it bubbles like hell if you have a leak).That way you dont have to remove anything that deosnt need to be removed:)
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
  • For sale 420A 420a heat shield
    $20 and free shipping. Need gone
    • Stizzydrew
  • For sale 420A 420a parts
    Stock Cam caps, lifters, rockers.
    • Stizzydrew
  • For sale 420A Stock 420a camshaft & cam gear
    Stock 420a camshaft and cam gears. $100 + shipping or best offer. I no longer will be using 420a...
    • Stizzydrew
