SharpShooter34
- 48
- Dec 1, 2002
I've swapped most of the 2G sensors over to the 1G motor. I do have a couple of questions though. The Manifold Differential Pressure Sensor on the 2G intake manifold. Do I need to swap that over and if so where do I install it on the 6 bolt? Same with the Ignition Power Transistor mounted next to the coil pack. Do I need it, I'm assuming I do, where should I mount that if I do? Only other query I have right now is this wire leading to a small cylindrical housing on a bracket on the driver-side rear of the intake manifold. I'm thinking it is a capacitor housing or something, but I'm not sure at all. I just need to know what it is and if it is necessary. Thanks a lot everyone.
Shooter
Shooter
