need help
mitsufrkr
95
Nov 20, 2002
birmingham, Alabama
the stock tech is not working and the gas gauge is not working . put in new glow gauges and i did touch the needle (move it) and now there not reading anything. did relpace the needle motor (not touchedat all learned my lesson first time) with one out of 90 1.8 laser but still not moving. please help.:( :laser:
ok guys i got the gas gauge working. now is there a sensor on the engine that transmitts the rpm to the gauge cluster.:(
-On the firewall left of the cruise control assm thereis a blank connector, you can read rpm signal if you tap a tach in it.
Originally posted by mitsufrkr
thanks but is there any way i could fix the one i have.
-I have never work behind the dash before so I can't give you advice on that, but you can try following the wire on the schemestic.
-I had been trying to post the photo of the connector you ask for, but kept getting the "server not found", PM me your address if you still want the photo.
