windowrattler
- Oct 30, 2002
How do you ground the ecu to check the timing? I know what plug it is but there is two connectors inside. So which one do you ground?
Also if the cam angle sensor was put in way off do you need to pull it out and turn it to get it within an acceptable range?
Thanks
Jason
Thanks
Jason
