92redman
- 1,096
- 6
- Oct 10, 2002
Holland,
Michigan
I've seen a few inquiries about the baro code in the 1g(code 25), but haven't found any diagnosis yet.
Here is my problem: Car had hard startup and a CEL came on going down the road. I suspected the ECU and so I took it out and put new caps in but that didn't help. I finally got a DRB scan tool on and found out it was the baro sensor and it was giving me a reading of 37.3 inMg which I think is the default.
I checked the power and sensor ground on the connector to the MAS and got 12.4V and I got a 4.9V on the other two. Should I have gotten that reading for the baro signal wire? because I was told that it probably wasn't biased and so I would have to do a continuity test from the connector to the ECU pin.
Prolly should add that I tried plugging in a different MAS but that may not be good either.
Any insight?
Any insight?
