9d7gst
- Feb 21, 2002
I have recently finished swapping a 94 non-turbo head on my 97 GST.
I used the valvetrain that was in the head. Im guessing its the same as a turbo model. I swapped the cams with 1G turbo cams. I installed and wired a 1G CAS to do the ignition timing. I used the non turbo intake manifold and blocked off the EGR. I kept the 2G coil pack and the 2G throttle body. I switched plug wires 1&4 and 2&3. I kept the injector wiring the same.
The car started up on the first crank but something is wrong. It idles like a BIG set of cams and only pulls 7lbs of vaccume. I checked the belt timing and everything is correct.
When I went on a test drive, I noticed power loss in the low rpm's. Up high is a different story. It pulls through redline with no problem. I have also noticed it running leaner than before.
I know the cams are what I stated before because they came from a reputable source.
WHAT IS THE PROBLEM?????
Mabey a bent valve on startup? (It made alot of noise) Mabey the throttle body? I did a pressure test with good results. Mabey I need a 1G coil pack.
Im just looking for another perspective. Thanks
