unior
- 519
- Oct 10, 2002
Lancaster,
Pennsylvania
question my car has been having some vacuum issues recently. Before I
would get a solid 20 inches at idle no matter what. I was also always getting
25 inches or so under deceleration. Now I am getting random readings.
Sometimes I get the normal vacuum at idle but I have seen readings as bad as
16inches at idle and 20.5 under deceleration. I checked my compression and
got 163, 162, 155, 155 - and I think I got lower readings on the last 2 since
I couldn't find what fuse to unplug to stop the injectors from firing.
So, could this be my timing belt stretching close to the limits? Also I have
had slight idle problems. Idles always stable just idles a little high
somtimes (1000 rpm) but the low vacuum situations don't match up with the
idle situations.
Should I be replacing my timing belt before I go 16g? Will the bigger turbo be
putting more stress on teh belt?
also anyone know if the kevlar timing belt is worth it?
thanks in advance, Jr.
idle situations.
