c2joe
- Jul 29, 2002
I have a problem that has begun in the last 2 weeks with the car hesitating. It happens when the car is fully warmed up, and the outside temperature is around
or above 90 degrees.
When out driving (normal conditions, no WOT runs) in 3rd, 4th or 5th gear around 3000 rpm the car starts acting up. I can feel the car surge (almost like your in
a rocking chair), in steady pulses about a second apart. While this is happening the rpms stay the same, resistance on the gas pedal does get a little lighter. The problems do not occur when I go to slow down or stop. I've changed plugs (bpr6es .028 gap, and wires which didn't help, anyone have any ideas, had the similar thing happen? Car is a 99 GST, stock everything.
