Thunderskull
- 469
- Dec 10, 2002
Long Beach,
California
Ok, I was wondering what this could be though I have my suspicions. I just removed my aircan on my n/a Talon. The previous owner removed the lower honeycomb on the MAS. Now, I'm getting more power now according to the butt dyno. However, my idle is really crappy now and the car feels like it's about to die sometimes. Also, when I'm driving at low speeds, the car lurches like it's hitting fuel cut. It only does this after it warms up. I think it's due to hot engine air getting in. Could this be anything else?
Thanks
Thanks
I put the aircan on and put the clips down over the lip. This helped to secure the filter. It solved my problem. I still have a little miss at idle, but I had that before which is probably the result of the previous owner removing the lower honeycomb and the hot engine air. I'm going to make a dam around the aircan using carboard and heat insulation to see if can reduce my intake temps and nail that minor miss at idle. I cured the jerkiness though.
