NEADmike
- Aug 23, 2003
Ok here's the scenario, installed an ACT Clutch, turned on the car, car would not go into gear when the car is on, turned the car off, car will go into gear. Started the car with the clutch pushed all the way in and car jerked forward. Car will not grind the gear if I try to force it in when the car is running. I tried bleeding the clutch and the clutch fluid ran out before I noticed it. When I did, I filled it back up. Clutch pedal went limp. I adjusted the clutch pedal as far out as it could safely go. Got a MityVac and attempted to bleed the clutch with it. For a while nothing but air came out. Then fluid began to come with the air. I've gone through about 3/4 of a small bottle of brake fluid and been bleeding the clutch for over 2 hours. Is it just me or should bleeding the clutch not take nearly this long? So I checked for leaks under the master cylinder itself (In the engine bay) and at the pedal on the inside of the car through the firewall and it is all dry, no leaks. The slave cylinder is not leaking either. WTF?! What is going on? I am pretty sure that the clutch is not going into gear when it is on because the clutch needs to be bled, but the clutch won't bleed! It keeps on pulling out air. Maybe there is more air in the lines and maybe I should keep bleeding it? I doubt it though. So my question is, what is wrong here? Is there a definite way to tell if it's the slave cylinder, master cylinder or both before I go out and spend $200+ on them? They only have about 40,000 miles on em and seem fine to me, but who knows? Someone please shed some light on this situation! Thanks!
(Isn't always a good thing)
