Leaking oil help!!
krosTSI
243
Mar 28, 2003
I cant kick this leaking oil deal, it dumps the oil on the bottom of my tranny and on the flex section of the down pipe. This creates massive smoke behind my car during acceleration. i replaced the oil filter and the stud is tightned down with lock tyte. and i dont think that would the cause oile on the downpipe or the bottom of the tranny. Any suggestions to where the oil may be leaking. I honestly leak 2 quartz a day. Please help.
Thanks,
-KY
-Clean up the motor with some degreaser spray, then you should be able to trace the leak, if you're still having problem, take it to a shop, they put some dye into the oil and trace it with a black light.
