KEY ignition Wire colors
TERBOLASER
183
4
Jul 22, 2003
greensboro, North Carolina
WHat wire colors on the ignition are 12 volts constant like BATTERY positive 12V , accessorys , and On ( like as in when you leave the key in the on position what wire is that no i dont want a wire harness for the type 1 i want to hard wire it and does ne one know what pin on the ecu is the vehicle speed sensor
I"m assuming that if I was to just buy the harness, then I wouldn't have to do all this wiring stuff??? I have an aftermarket alarm though and I want to be able to arm my car while it is idling.
