Help Me Please!!!
NEADmike
Aug 23, 2003
Just installed ACT Clutch. Car won't go into gear when car is started. Car will go into gear when off. When the car is started, it sounds like the release bearing is rattling really badly. Almost seems like the clutch isn't disengaging. Any ideas on what to do? Is there anyway to adjust the clutch pedal? HELP ME!!!
Best regards,
Mike
NorthEast Auto Design
www.ForPerformance.com
www.NorthEastAutoDesign.com
1.800.296.6560 ext. 202
a really long time ago i remember hearing miguels3000 or some user by that name having same problems with a new clutch. Go for a PM and check how he fixed it. Good luck :)
There could be many things, did you have the flywheel machined? Did you bleed your clutch again? Adjust your MC rod. Did you shim the ballstud on the tranny? Trial and error.
