pimpngear
- 101
- Jan 22, 2003
Arlnington,
Virginia
I am completly fed up with this beast. I guess i should start from the root. I pulled off the head to swap out the headgasket for a cooling issuie(different thread, still not resolved) and now that it is all back together I can't get it to run right. Processes.....
1. Pulled Head, decked head (not first time), new stock gaskets all around.
2. Re-assymbled everything, re-used tensioner and belt (oops)...car runs like A$$
3. Pulled assymbly apart, put everything in perfect time, new tensioner and belts. reassymbled.... runs like A$$
4. Pulled assymbly apart, changed out valve seals, reassymbled....ASS again
5. Pulled assymbly apart to repair Cam Position Sensor form step 4, reassymbled......runs like A$$
6. like magic found broken coil pack for #1 & #4, changed...A$$, but nowhere near as bad
7. Pulled assmbly apart for giggles (I can now do a timing belt in about 1 and a half hrs. from start to finish), changed plugs, borrowed known good wires.......A$$
I am now fixing all other known problems as not to confuse the wrench turner when I slam this hunk of sh!t. I forgot to mention this. As the car is now if I reset the ecu the car will run, it runs like A$$, but it still runs. if you turm it off then turn it back on, it will only run for 5 seconds...nomatter what. but if you re-set the ecu you can do it all over again. I actually think my answer lies within this, but I don't see it. Any opinion will be greatly appreciated as labor rates around northern virginia are 85 an houre, so i am in no rush to get it to a shop. Thanks for sharing in on my pain.
-Robert
-Robert
