Omega
- 1,558
- 10
- Oct 10, 2002
Randolph,
New Jersey
My aftermarket gauges are doing some WEIRD shit. A few months ago I bought an air temp gauge. The sender is mounted in the Al elbow, but I added a ground strap directly to the battery. The power for it was hooked into the parking lamps. Whenever I turned on the headlight/parking lights, the air temp would jump up 30-40 deg. I figured it was from where I got the power source from.
Fast forward to the EGT/FP gauges (both electronic). I moved the power wire from the lamps to the cig lighter fuse. I am getting the same problem!! What the hell is going on here!?
There is a .3V difference with the parking lights on, but there seems to be nothing I can do about that. I can't try it with the engine running because it is late and the exhaust is laying on the floor.
HELP!
HELP!
I hooked them up directly to the battery at one point so I knew they would work properly
