After Market Alarm Wiring Help
awdclipse
42
Dec 18, 2004
Germantown, Maryland
I've got most of the easy stuff hooked up, and now I'm on to the door locks and windows. After reading some threads, I have a rough idea but still need some help. I've attached a picture with wires outlined in red that I'm not sure exactly which they connect to. If anyone can help it would be greatly appreciated. Thanks
From top of picture to bottom:
Window roll up output (-)-
Door Trigger (+)- brown/white?
Door Trigger (-)- brown?
Cut off Port-
To central lock
I'm guessing some of these aren't used because its only 2 door?
These wires to central lock?
Lock Motor blue/black 5wire
Unlock Motor blue/red 5wi
Orange-
White-
Yellow-
Orange/Black-
Black/White-
Black/Yellow-
Also the relay supplied is not shown in the wiring diagram. How is it incorporated? Engine off circuit?
The window roll-up you want use unless you have a roll-up module. And you will be using the negative(-) door trigger. Which will hook to a red/green wire in the drivers kick panel or behind the dash. The cut-off port im not sure what that is for. And the doorlocks are 5wire meaning the alarm has built in relays. So 2 wires are going to be input which will either go to ground or 12 volt. Then 2 wires are not going to be used then the other 2 wires are your output wires. Or some alarms phrase it this way for the wiring- 2 wires are common which are your output wires to the car door locks, 2 wires are n/c which you want use and 2 wires are n/o which will go to either ground or 12 volt, which on your car will go to ground.
But read on your instructions and make sure or post up what it says about the locks and i will try to help you furthere
So you are saying i can or cannot use the window roll up?
To make sure, i only use the negative door trigger and not the positive one and that wire goes to a red/green wire? Is there anyway you could be more specific as to which wires go to the "central lock" wires. There really isn't any other instructions other than the wiring diagram.
Unless you have a window roll-up module that wire want get used unless the alarm has the module built in which i dont think it does having a negative output because that want activate teh windows without having relays on it. And yes you will only use the negative door trigger wire just besure and test the red/green wire to make sure it goes ground when you open up the doors and the rear hatch. The place were i found my wire at was behind the dash part that you remove. And i doen know anymore about the door lock wires without knowing what all the wires are. The alarm you have has built in relays and you have to wire them properly or you will fry something. Does it give any numbers like 87, 87a, 30, 85,86. or does it give normally open and normally closed or n/c, n/o. I will have to know alittle more than just what its shows on here
