97GSRyan
- 73
- Dec 14, 2007
Inland Empire,
California
I have a 97 non-turbo, with a worsening stutter problem. I've researched, and the only threads I came across were for turbos. The car normally runs fine, but when it's hot out (around 95+ degrees) it stutters under acceleration. It seems to be more pronounced the harder I press the gas, which tells me fuel delivery? Also it seems worse when the A/C is on.. Only known issue with the car is a "small EVAP control leak" but I'm not sure if that would be related?
So there it is-
1. Stutters worse with wider throttle
2. Stutters worse with A/C on
3. Seems to be caused by heat
4. EVAP control leak possibly related?
Any help/suggestions would be greatly appreciated, thanks.
So there it is-
So far, the spark plugs being properly gapped seems to have cured my stutter/stumble issue. Now I wanted to add another question, since I've searched and can't find much on the subject.
It holds vacuum with no voltage applied and purges with voltage. Anyone ever heard of this before? The terminal resistance is within spec too which is confusing me. Any help would be greatly appreciated!
