Ja17Bmx
- 91
- Oct 16, 2004
Doylestown,
Ohio
I have no idea on this one, so I came to the experts for some help. The first time you boost the car, no matter what ( just started, been driving for awhile without wot) the car will build boost up the set 16 psi and then stop, studder and drop to 8-9 psi. Then after it does that, it will only build 8-9 pounds of boost in any gear until the car is shut off and drove again later. I have no idea whats going on? I did a thurough boost leak test, testing each part of the ic piping at a time and came up with no leaks.
The logger doesnt show anything abnormal, no execssive knock or anything. Im stumped on this one. When it goes up to 16 psi the one time it will, the car pulls excellent and the turbo doesnt make any weird noises. I checked the turbo for shaft play and it didnt have any. If i connect the line from the wastegate actuator to the nipple on the J pipe, no matter what the car will just build 8-9 psi and it holds it to redline without doing the said problem above. Its not until that my buschur boost controller is on the car that it acts up. Any insight to my problem will be greatly appreciated.
