Clutch problem.
JMiller
684
Jun 30, 2007
Irmo, South Carolina
I have a new Master cylinder, slaver cylinder and a new clutch line, i also bleed the system. But for some reason after i adjusted the pedal and got it at the right spot(test going up and down driveway) When i drove around the neighborhood the pedal got real loose and when i came to a stop it went straight to the floor and stayed there. I know its not leaking, so what might be the problem. Every time the car is in the drive way the clutch is fine even when going back and forth. One more thing when the clutch pedal got loose the engagement point changed from about halfway up to as soon as you lift your foot(about 1 inch off the floor). Any help would be great. the only other thing i can think of would be to take it to a shop and have them try to fix it. :dsm:
A new clutch will engage as soon as you try to take your foot of the pedal it will do that for the next 200 to 500 miles till the clutch brakes inn..
About the other problem i would try to re bleed the system once again it could be possible that you did not take all the air bubbles out..
OK i bleed the system again and the same thing is happening. When im at a stop or moving really slow the clutch is fine but when moving above 8mph the clutch get real loose and and the gets pulled to the floor. But as soon as i slow down or stop and its perfectly fine no pumping of the clutch at all, when i stop it goes back to perfect.
