BoostedPhoenix
- 159
- May 29, 2007
Osage,
Iowa
I'll start out by saying, im not new to cars, and im actually a technician at a Saab dealership and feel embarassed to say im ASE certified to the point of Master tecnician, but have absolutely no experience with the guts of an all wheel drive transmission. My car is a '94 Talon TSi AWD manual transmission. My problem started last night when i was driving home (150 miles) and as i exited the interstate and tried to accelerate onto the highway, the engine practically free reved and the car didnt accelerate. I say practically because it did go a little but i recognized the problem right away and let off. As happens always in these situations i attempted it again, and the car would slowly accelerate if i nursed it up to speed, almost as if i had completely destroyed my clutch. I was not near a place where i could pull over and it seemed to be cruising just fine in 5th gear so i stayed with traffic and continued home. I arrived in my home town and was then forced to slow down and try my luck through the stop lights. The trans will slip like crazy when in gears 1, 2, and 3, but i left it in 3rd in town and tried to time the stoplights so i didnt stop. One thing i noticed was that while cruising in town i turned the radio off and listened for any noises, there sounds like a whining noise when at a steady speed that is accompanied by a slight clunk that is felt through the car at slower speeds. Once in my driveway i tried reverse and 1st back and forth and the gears are all there as they should be. What leads me away from the clutch itself is that in reverse i can hear the reverse gear whining inside the transmission spinning at the same speed as the engine while the rest of the car only seems to be going at half that at best.
My orginal diagnosis would have been clutch until i heard reverse, and now im thinking more like center differential. From my searches though i have read that the center diff usually causes alot of jerking when going around turns and such but i really dont know powerflow through one of these with that viscous clutch there it seemed like a possability.
My question is this, anyone else ever see a problem similar or know what direction to point me...if i dont have to pull the trans i dont really want to
we all know how much fun that is.
Yeah, well the only reason I know this can be a possiblity is because Ive had the pleasure of dealing with it myself, more than once. Mine had slung axle grease everywhere when the bracket bolts broke so it sounds like that's probably what has happened. Let me know what you find!
