car wont start
iammikesevvy
30
Nov 15, 2006
howell, New Jersey
ok i just got my car back from the paintshop and it wont start now :mad:....im going to make them fix it but i need to find out whats wrong first. I have a guy looking at my car for me and hes changed the plugs, all the fuses are good, fuel pump works, and i have injector pulse so my ecu is working...and he still cant figure it out...anyone have ideas?
yea everything is good...i have fuel, i have spark, i have compression, and the timing is good....the cam senor was changed the colant temp works, i changed ecus, and i have gas in the car LOL....i have no idea what to do
have you checked grounds, and have you checked the starter, does the car make any noises when you try and start it, check if your batterys still good. need a little more detail thought of what the car sounds like or is doing when you try and start it, have you tried to push start it.
the car just cranks but wont turn over and yea the push start didnt work...and im pretty sure all the fuses are good
