soldave
- 737
- 1
- Feb 17, 2008
Okinawa, Japan,
Asia
Wonder if I can get your thoughts on this little problem I encountered at a drag tournament today. Got an Ostrich real-time emulator in my car and have tuned an Evo 2 map to my specs. Today I must have had about 8 runs in total. 6 of them were fine but on 2 of them (and one in particular) I had a strange problem.
I launched at 5200rpm and after a little wheel spin I hooked up fine. Went up the rpm range to my shifting point at about 7,300rpm. Then when I dropped into 2nd the car felt like it was misfiring and not pulling nearly as hard as it should. Did it through 2nd and into 3rd. Then from about 4,000rpm in 3rd it went back to normal and pulled really hard again. But then the next run I could go straight away again and it would pull fine. Also, if I go from a roll all the way up 2nd and 3rd gear, there's no misfiring.
Any thoughts what it could be? Have just got some new Iridium plugs in there so I sincerely doubt it's that. If you need any more info for diagnosis purposes, let me know.
They only do it to you when they know it'll piss you off the most. I say just try the NGK's, might work, might not, but it's a good place to start. I don't see why it would target one gear, unless maybe it's the way your air/fuel is set up and a certain point in your 2nd gear it triggers the hesitation (possibly ?). Just a guess though, try the NGK's and let us know if that helps it out.
