99GST
- 245
- Dec 26, 2001
Nashville,
Tennessee
I am getting a CEL # PO125 which is Insufficient Cooling Temp for Closed Loop Control.
DarkOne was nice enough to tell me that I probably have a bad coolant temp sensor, or a bad thermostat. Either my coolant is not getting hot enough for the ECU to switch into closed loop, or my coolant temp sensor is misreporting the temp and the same result happens. So my car is stuck in warm-up mode, and it will run nasty rich trying to warm up the car.
How do I tell which is bad? The coolant temp sensor or the thermostat? The factory temperature gauge is where it should be just below the center mark.
Any ideas or suggestions? Please let me know, as I am clueless on this one.
Thanks,
Nathan
Thanks,
Nathan
