Jetrosr
- 191
- 1
- Jan 10, 2008
Indianapolis,
Indiana
92 turbo, ran for about 15 min.( just got it), but not very well. Died, won't restart. Noticed ECU no longer bulb checks after it died. Removed ECU and found leaking caps, fixed the ECU from instructions on the net
. Reinstalled ECU with much anticipation. No bulb check and crank no start. I found some info on a relay that switches the ECU on under the center console, wondered if this sounds like a relay failure, I just flubbed the ECU fix OR ECU was damaged beyond the cap replacement? Car has been sitting for about a year. The car is still at the previous owners house, I haven't been back over to see what pins have juice. Hoping someone has been there done that. Thanks!
. Just curious if the situation you speak of the car lost bulb check before the caps were replaced? The leaking cap took out a ceramic capacitor (tiny rectangular block) and ate a hole in the copper trace on the PCB. I don't have a bunch of confidence in my repairs to that part of it. My budget is pretty small after Christmas, so I'm stuck with with near free stuff until tax checks or some other bank booster arrives. I noticed one of the replacement caps is about 1/2 the size of the original, anyone used these with success?
