holb
- 36
- Dec 22, 2007
Columbus,
Georgia
I was driving my car last night, nothing to crazy just driving and it was raining... everything on this car seems to mess up when it rains... Well I was driving down the highway and hit 100% throttle in 4th and the car kinda of jerked or bowed down instead of going in where. I looked down and seen the CEL was on. So I went home and parked the car.
Today I woke up to drive and make a CEL kit for the car and it would start then just die. It would do this until I finally got it harmed up good. Got the parts and then hooked it up... The light blinks were Steady for 10mins, nothing... So i got in the car with the CEL still on, cranked up fine... but here are the issues and such...
1. The car would just die unless I turned the TPS up in the 1300+rpm idle range, anything less and the car would die out....
2. The exhaust note has a pretty laud ticking noise in it...
3. Engine shakes bad but not crazy bad...
4. under light throttle car drive decent, sounds bad but drives smooth...
5. under heavy throttle the car bows/bogs down BAD!!! until it hits high boost (10+)...
6. The rpms seem to be going up ALOT faster than normal on the SAFC but the car doesn't feel like it at the RPM it displays at all VIA: 5k on the SAFC feels like 1.5k-2k, my reg RPM gauge in cluster doesn't work...
7. builds boost fine, slow around 0+ - 5+ but after that builds fast... (always done this)...
8. CEL is on but doesn't throw a code...
Mods:
-Small 16g
-550cc
-SAFC2 (was tuned then switched to default when this problem started to happen to see if it was the tune)
-chipped 2g MAFS
-FMIC
-greddy BOV
-rebuilt motor (est 10k-20k miles on it)
-new spark plugs and wires
Checked: spark, fuel pump, cel,
Mods:
-Small 16g
-550cc
-chipped 2g MAFS
-FMIC
-greddy BOV
