t3t4 more problems
marksawdtt
Dec 11, 2007
sprucepine, North Carolina
what would cause my turbo to start leaking oil into the exaust...this turbo is NEW!!
Sounds like too much pressure to it. Are you pulling your oil source from teh oil filter housing or the stock 1g feed area on the head?
the turbo is just a t3t4 hybrid..ar50. yes i am using the oil feed from the head.... bs removed??? what?
no.. to tell you the truth i have just about had it with this car. i have put so much cash into it and i still cant get it right. i bought two turbos because i thought the first one was bad and when i got the second one i put it on just to realise i had the oil going in the wrong way. so i fixed that then took it for a test drive and cant get the car to boost right so i got a little help from here and still nothing. well i think it might be my exaust because i took a piece of 2.5" pipe cut a 45 degree angle in it and welded it. and when i took it to my muffler shop to have a smoother 90 degree pipe on it is when i started to have this problem....... it just keeps getting betterLOL
You had the oil going in the wrong way? You fed it through the return and hooked the return up to the oil pan?
