Captain D
- 51
- Feb 18, 2007
Monument,
Colorado
I bought a 92 GSX back in January and I have been fixing problems the previous owner created ever since. I think I found another problem. My oil dipstick has recently started to pop out. I went to check the PCV valve to see if it was working properly and I noticed that the pcv line from the pcv valve was connected to what appears to be the purge control valve underneath the battery. Should the pcv line be connected to the intake manifold instead? There is a vacuum port on the manifold that is capped off about 3 to 4 inches away from the pcv valve, is that where the line should be connected to? If it is where does the large hose from the purge control valve connect to? Thanks for any help...........
