No Spark: Coil ans PT ok! how to test CAS?
luizdiefenbach
32
2
Jan 6, 2003
Brazil, South America
My 1992 Gsx doesn't get spark.
I already tested the coil primary and secondary, everything ok
After that I tested the Power transistor and it turned out fine.
the next in list is the CAS (camshaft angle sensor) but on the service manual it only says "refer to group 13A - troubleshooting"
But that group 13A isn't on the CD manual!!!!
I searched all: the CD manual, dsmtuners, dsmsource, teamnabr, dsmlink forums, and found nothing about testing the CAS.
How it can be done?
or if you found a link please post here or email me at [email protected]
thanks a lot
thanks a lot wiseman for your compreension.
I found the problem: broken wire at CAS plug (the one you tap for signal for MAFT)
Everything ok now!
thanks a lot for the space and for the link!:thumb:
