No Spark
91dsm505
Jul 7, 2007
Albuquerque, New Mexico
i have a 1991 Eclipse GSX and i cant get the damn thing to turn over. im getting fuel and everything and i dont know why it wont turn over... maybe no spark or something, i dont know...any idea on what i can check over to get this car runnin. please help!!!!!!!!!!
simple way to check for spark is take the spark plug wire off put a screw driver inside of it and then make sure you put it close to the good ground [ex. valve cover]. Let somebody crank the car if you see sparking arching you have spark.
I would add to the possible cas that perhaps you may be the lucky recipient of leaking Rubicon capacitors which sometimes kill the computer. Cam angle sensors are relatively cheap and I highly recommend one in your tool box. Finding one at the dealer will cause you to puke. Price wise that is. Good Job Karma.
Quoted 790$ canadian at the dealership, that is cost too!
When installing it, make sure you put the dot in the same spot it was in.
Good luck
Where can you buy a Cam Angle Sensor from? (besides a dealership) Does Mach V or a similar place sell them?
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
  • For sale 4G63 Used FP 4G63 Turbo Manifold
    Used FP 4G63 Turbo Manifold removed from 1G Talon. Looks okay, needs a cleaning. Did not see any...
    • Badge023
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
