phase17
- May 20, 2006
Green Bay/ Milwaukee,
Wisconsin
I have a 1991 Talon TSi. Only mods are BSC restrictor removed. I had a boost gauge hooked up and it read 15psi consitently for quite some time. Well it broke so I drove without it for a while. In that time I used a datalogger and messed with getting my base timing correct. Today I hooked up my friends boost gauge to see how things looked and I was pushing 23psi. The first WOT it topped out at 15psi like before, but as I kept driving boost kept increasing until it was at 23psi. The car accelerated slower each time as well. I searched and figured it must be the wastegate. I read that if I run a hose from the jpipe to the wastegate only and boost exceeded 7-8psi then it was bad. Well it went to 23 just like before. So overall I just want to know if this sounds like it's definitely my wastegate, or if something else could be causing the issue.
