perley03
- 585
- 14
- Apr 29, 2006
Bangor,
Maine
Last night on my 80 mile trip back home I noticed that my dash lights were flickering with every second. Like they would be bright for 1 sec, then dim for 1 sec, and repeated itself until I shut the car off. Also I noticed that 2 lights were on simultaneously and would flicker on and off, but not with the same sequance of the dash lights. They were the brake and low coolant light, and they both would come on and off at the same time. What is going on, I have a brand new battery with new terminals. Voltage at the terminals with car idling is 13.3V, and when it is at 3krpms it is at 13.8V
Also only in 1st gear, when I take off and get into it, it boosts up to 15psi, but the car does not pull, and the RPM's really don't climb. As soon as I shift into 2nd though, everything is fine and it pulls like it should. It just started doing this last night as well, so I figured that they were connected somehow.
Does anyone have an answer to this, because it is leaving me stumpted.
