fallout941
- Jun 27, 2007
Valdosta,
Georgia
I got a 99 RS with an MT on the 24th. I had to drive it back, which was a 4 hour drive. I figured that would bring out any problems the car would have, and the car ran fine with one major exception.
I had been driving for a good hour and a half when the engine just stops....at 75 MPH. Both the speedo and tach go to 0. I pull the car off the road, try to see if the car is getting fuel, it is. i check the ignition plugs, they are fine. I try to start the car 3 or 4 times, and it just keeps turning over, not actually starting. I take the key out of the ignition, fiddle with some other stuff, and try to start the car again, starts right up.
I start driving again, decide to stop to get something to eat. I get off the exit, damn thing dies again. Again, both gauges go to 0. i try fiddling with some things, and again, after taking the key out and trying to start the car, it starts right up.
It happens again on the way back, with the same fix (I didnt realize at the time that it was starting right back up after removing the key)
I was told that the fuel pump relay going bad would cause symptoms like this. I do not know if this is true.
The car has no problems whatsoever when starting from a cold start. It doesnt ever have any problems starting period. My thinking is that the heat from the engine makes something in the relay expand, causing the failure. I have no idea, however, and would love some input from anyone, especially from someone who has had the same symptoms.
Thanks in advance for all replies.
