dyno/ bad hp help!!!
player69x
39
Dec 21, 2006
Sunrise, Florida
I have a 1996 eagle talon tsi automatic with upgraded injectors , walboro 255, evo 3 manifold, 3 inch turbo back exhaust, ajustable fuel pressure regulator, big t28, apexi neo and a boost controller. I dyno tuned my car today and we turned to boost up to 16 pounds and the most hp i was able to see was 172hp i was expecting way more does that look correct or is something wrong?
motor was taken out of another gst about 2 months ago did the compression test then and it was good. did not do a boost leak test but i check all my vacum hoses and tighten all my clamps. Those numbers are bad right?
well i tore up my engine and broke my throddle body but i found out that i had 4 vacum hoses that were not connected and one was broke. so im guessing thats why i dynoed so low but i will fix the throddle body tomorrow and i see if i see any difference.
I have exactly the same problem... But I have an 'almost' stock 95 GST though...
My engine has the balance shafts removed, a cone air filter and OML 10.3mm spark plugs wires... BPR6ES NGK's spark plugs...
ANd I dynoed 125 hp.... :cry: .... Can my problem be related to boost leak too?
one of the vacum hoses on the car spilt into 3 with a T. does it matter where i put what vacum hose?
    • eclipsemf
