bluesbabybones
- 105
- Oct 15, 2002
Milton,
Florida
Well heres my problem. I have a 6 bolt in my 95 GST. My car cranks. It turns over but it just won't start. I have dsmlink,which has helped me alot. I'm not getting any codes. I have a fp gauge and its getting pressure. My injectors are brand new. I checked for spark and I'm getting spark for all 4 cylinders. I was thinking that my cas was the culprit but it seems to be working fine. My firing order is 3214. I also tried 2341 to no avail.
The invert cas box is checked on dsmlink. I also had a compression test done it and it was good also. The one thing I'm not sure about is on dsmlink my isc,mdp and tps all cannot be logged at all. I can't receive any data on it at all. I can't even adjust the tps. Which I'm wondering if that may be because theyre not getting power. I'm not sure. I know it isnt a problem with dsmlink cause it worked before. Any help would be greatly appreciated. Oldman,if you're out there...I need ya.
