Ike66
- 59
- Dec 4, 2006
apollo,
Pennsylvania
OK so i have one of those seven color illuminated shift knobs that a friend of mine gave me for free. I like it alot nicer than the stock one, but it went through a set of batteries in like a month....so i figured i would hardwire it. I ran my own battery wire (15 amp fused) directly from the battery and connected it to a wire that was already on the shift knob. The shift knob only runs on 2 3volt disc style batteries so i threw a 330 ohms resistor inline before the 28guage wire i ran from the circut board in the shift knob. Im not sure if this is too big of a resistor or not but thats what i use for LEDs and thats whats in the shift knob. Now the problem im having is that sometimes when the car is not running and the horn is pressed or if i make the horn chirp with my keyless entry the knob will go through an LED sysle that it normally only goes through when you first replace the batteries. Could it be that because of the resistor the horn is drawing enough power to completly take power away from the sift knob for a little bit and if so what size resistor should i use.
Thanks for any help
Thanks for any help
