zdrux
- 79
- Jun 7, 2003
Mississauga,
Let me get right to the chase. Recently I've been getting a coolant temp sensor code which I shruged off as a bad connection to be looked at later. Few days ago, this code has stopped popping up at all (I have dsmlink).
Today on my way to work, the car drove fine. I parked, then came out an hour later to go to the store and the car dies when revved past 2k rpm. No codes at this point.. I can drive it if I keep the throttle at like no more than 5% open, otherwise it bogs out, and you can smell unburned fuel from the exhaust so I`m guessing it's getting flodded with fuel.
I limped it back, and then suddenly got 2 error codes - so I whipped out my dsmlink and it had "coolant sensor" and "airflow volume sensor" error codes... So I`m guessing that's why my car was bogging, it wasnt receiving an airflow signal and they may be related.
Some (a lot?) has been done on the car, and I've had electrical issues in the past (for example the ISC shorting out) - and I`m wondering if perhaps both of these sensors are on the same ground?! I`m assuming they are grounded at the ECU, does anybody know if this would make sense? If so, where would I check, at the ECU? Any chassis grounds I should also be looking at?
The sensors themselves are ofcourse plugged in and all the wires are there.
