hatch
- 51
- Nov 1, 2006
Centerville,
Georgia
Vehicle Info:
1990 Eclipse GSX
157,000 miles
Supposedly rebuilt 12-15k ago, head looks new/cleaned up really well compared to the block
Big 16G running 16psi
Stock fuel system
Stock SMIC
Turbo timer
Background info:
I bought the car for $1250, it ran fine except for a little blip of hesitation at idle every few seconds. Previous owner said the engine had been rebuilt with a new head about 12k miles ago. After owning it for a month or so I noticed a sound of like water trickling, couldn't really tell where it was coming from and didn't really think much about it.
How it happened:
On the cold days the car had started to want to boost spike up to close to 20psi and would hit fuel cut rather quickly. On one particular day I left work and proceeded to my usual interstate on ramp romp fest. I took it up to 80-90 and slowed back down, merged with traffic and was happy because the car seemed to have run its best ever, it pulled hard, and didn't spike boost and hit fuel cut. I leisurely drove up the interstate for probably 10 miles to my exit, car was fine at this point no odd noises, definitely no knocking, however I wasn't paying attention to the oil pressure at this point so I don't know what it was doing. I exited off and came to a stop at the red light, as soon as the light turned green and I gave it some gas...KNOCK KNOCK KNOCK. I limped it home (1-2 miles) and on the way noticed the oil pressure. When I got home I turned it off, but due to the turbo timer it ran for a little while, at this point I noticed that at idle it didn't knock at all, but if I blipped the throttle a tiny bit it knocked.
Where I'm at now:
The car is sitting in my garage, I'm transporting it up to my dad's house (he has a nice shop) this weekend. I haven't done any kind of tests on it or anything at this point. What are some things that could have happened? What should I look for? We are pretty much planning on pulling the engine at this point and performing a rebuild. But could it just be the oil pump or oil pump seals or something along those lines? With the knocking though I feel like I have probably bent a rod, but the 6-bolt rods are supposed to be pretty stout. I guess I could have floated a valve and smacked a piston, but whats throwing me off is the fact that it doesn't knock at idle.
Thanks, any input is appreciated, I just want some ideas of what to look for once we start working on it. I have already gotten the Chilton manual and done some reading, but this will be the first time I've done any major kind of engine work.
1990 Eclipse GSX
157,000 miles
Stock fuel system
Stock SMIC
Turbo timer
Background info:
How it happened:
Where I'm at now:
