Car won't start!
hiimt0ny
70
2
Mar 25, 2005
new orleans, Louisiana
Okay so i just pulled the charcoal canister and changed my throttle body, car ran for a week and now it won't start. I have an aeromotive fpr with a gauge and when i try to start it the car gets fuel pressure, so i am guessing it's not getting spark or the timing is off... i am going to check the spark and if im not getting any i will check the coils. i'm just wondering if anyone else might have any other tips....
I think you are on the right track, compression check, and spark check are the next things to look at.
How do you check the transistor pack? i dont see it in the haynes manual.... ill look again but if anyone has a write up or anything, that would be awsome...
yeah i got the haynes manual and i found the transistor pack in it but its hard to understand from the haynes book i just ordered the chilton's...
im not getting spark i tested it the other day so imma test the coil and the transistor.
what do i have to test around the transistor pack? the coils? battery? and what else? also what coils work with what years? for a 92 can i only use another 92 coil pack?
91-92-93-94 will all work for coil packs. Check that, the cas, the battery voltage at the transistor. Make sure no fuses are blown and that the cams are spinning.
  • Wanted 2g ISO Rear Pass EDM Tail light
    Looking for only a passenger rear EDM tail light for my 2g. Please lmk if you have one lying...
    • Gabriel Pena
  • Wanted 4G63 ISO built short block
    Looking for either a 7 bolt split thrust or 6 bolt
    • Gabriel Pena
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale 2g 1996 Eagle Talon TSI AWD
    I have a 96 Eagle Talon AWD standard tranny for sale. The car still ran when I parked it. I had...
    • eli1977
  • For sale 2g 2g front strut shock cup. MR103156. New.
    Mitsubishi Oem # MR103156 front suspension strut cup. New. Message 702-741-6987.
