6 bolt swap. 2G harness connector MADNESS!!
Cesar
519
May 24, 2003
Titusville, Florida
okay guys, I need a little help.
I have dropped the motor in, and it cranks fine.
However I am in the process of trouble shooting my no start problem.
Before I perform a compression test, would like to ensure that all of my connectors are plugged in the right place.
Are any of you able to tell me the color of the wires leading to the following connectors?
1 coil pack
2 2g cranksensor
3 2g AC compressor
They are all in the same area and are all triagle connectors that interchange.
Thanks
The A/C connector has a green an a white wire. The coil pack and the Crank angle sensor are both red, blue and black. The Crank angle sensor connector is the one that is closer to the timing belt.
My car fired up, but then died. I think I need to adjust the idle and timing for it to keep running.
