sakrafice
- 217
- 1
- May 28, 2003
Sumpter,
Michigan
Just finished the swap in my 95 tsi and used stock 2g head. the car cranks over, i checked plugs for spark and am getting spark on all cylinders... i looked for fuel, just unbolted the line that runs into the fuel rail and it had the fuel up there... i pull the plugs and there all oily... I really dont know what to do.. maybe check grounds?? check to see if the injectors are working... I need some ideas for tomorrow..
Also im not hearing my fuel pump at all... but fuel is in fuel rail so it has to be working right?? it dont have like a vac when its cranking or something does it?
I used the RRE Harness , i havent done the injector swap however i was told the car would fire just not run as nice as it could. I will be doing it but for now im just trying to see it run b4 i start putting the car all the way back together..
