Passion 4 Speed
- 198
- Jul 26, 2004
kissimmee,
Florida
hey guys, i just installed a new head gasket and arp bolts in my car..it ran fined after i put everything back together..couple of hours later my car was very hard to start..once it did, crappy idle, extremly slow revving..no boost whatsoever.
datalogger picked up code 41 injector circuit..so far i checked..
all connections,ecu,and injector harness..
ecu is fine no leaking caps..
all connections are fine expect one..theres a vac hose on the intake manifold right between the fuel injectors (next to spark plugs) .. i dont know where it connects to..(i use to have my boost gauge installed with the fpr hose, after i did the headgasket/bolts job i didnt get any readings from my boost gauge like before?)
the harness on the injectors dont have any metal clips..but it has been like that since i bought the car
the only way i could test the issue was using my datalogger, i got the car started with its crappy idle..tested each injector while running heres what i got
1-2-3 all idles way worse when off..
but the 4th injector when i select it nothing happens same crappy idle
pulled the plug from injector 4 theres a lil bit of wet/dirt inside..cleaned it up with a dry paper towel..still nothing doesnt even start now..
i tried resseting my ecu..same results..
so far im thinking that one injector is shot..is there any other way i could check for trouble shooting? visually checking that one injector??
thanks so much in advance
