STIZZANG
- Feb 18, 2006
Des Moines,
Iowa
hey guys! here's the scoop...97 GSX 5-speed...brand new motor...go to fire it up for the first time..."click"...so after a few mins of swearing, and making a stiff drink....i begin diagnosis...i have switched starters with a car that is currently running perfect...ecu's...starter relays...all fuses check out ok...motor turns over nice and free by hand...checked and compared all grounds (even tried re-locating a few) still have the nastly click @ the relay. this is a bone stock motor with no changes what so ever from the factory setup. all sensor's are plugged in properly. i am running out of ideas...i'm going to bring a multi-meter and circuit tester home from work tomorrow but i thought it might be a good idea to check with you guys first to see if anyone has run into this problem before. thanks in advance for your help!!
