Temp gauge failure
chuckg
69
Dec 7, 2005
Springfield, Missouri
Well my temp gauge stopped working. I checked the sensor at the bottom of the radiator and it looks ok. Where should I go from here??
Thanks in advance
Yes the gauge plugin should be at the thermostat housing or closeby. Only thing on the bottom of the radiator is the fan plugin. And visually looking at it won't tell you anything. Sensor's fail all the time. Did you unplug anything recently?
Yeah i have unplugged it lately. Ill check it out later today. My fan is still working... so i assume it's not the actual temp sensor, just a problem with the gauge. Is this possible?
