anyoen have a balance shaft sprocket for sale or know where to get the grommet on it?
sepulchral
61
2
Dec 9, 2005
midlo, Virginia
theres a rubber grommet that tore off of my balance shaft sproket.. does anyone have a sproket with one on it for sale or can i get that rubber washer/grommet seperatley??
Hi sepulchral,
I just checked the extra bs sprockets I have from doing the bs elimination on a 7 bolt and a 6 bolt and I see no rubber washer/grommet. I even checked CAPS. The program shows no type of rubber washer/grommet with the balance shaft sprockets. Can you provide more info or a picture of what you need?
Are you talking about the balance shaft seal that is in the front oil pump case?
Mike
I was thinking the same thing, Nanan.
sepulchral, if you are talking about the oil seal for the front balance shaft, I have a new one I can send you. It came out of the new front case I bought for my son's car. I did the bs elimination kit, so the oil seal wasn't needed. I can just put it in a regular envelope and mail it to you, no charge. I'll never have a use for it. PM me your name and address, if interested.
If you need it quicker than that, the Mitsubishi part number is MD343565.
Mike
i have an extra seal, the actual sproket itself has a rubber grommet insie of the hole where the bolt goes through, thanks neways man
