Blackbird 13
- 35
- Feb 7, 2004
Suffolk,
Virginia
Hey ya'll.. bought a 1990 Eagle Talon AWD at auction (M/T, Power everything.. $850 if you're wondering), and drove it about two months before my alternator went out. Dead.. completely dead, left me stranded. I jumped the car.. got enough power to limp it a mile or so to my aunt's house in the middle of the night with no lights. Anyway.. went back with a new battery, got it to my friend's auto shop, and we replaced the alternator, with one from a 2.0 Non-Turbo, A/T car. Not an exact replacement.. but it worked.. or so I thought.
So, last night, a month later, I started getting dim battery and brake lights on the dash at 2000 RPMs or under... a quick check to the cigarette lighter with a voltmeter showed I wasn't charging. I got the car home (thankfully), and went today to a junkyard, where I purchased an alternator off of what was a running 1990/91 Plymouth Laser Turbo, M/T, Power Windows/Doors.
Got back home, and I noticed upon removing the old one that the old alternator (remember, the one that came off the 2.0 Non Turbo A/T) had only one place to hook a ground up to, whereas this one has two (but I only have one ground wire). So.. I installed the alternator, after a lot of hassle, hooking the ground terminal to the prong furthest back. Also.. on my car.. it seems someone did a little rigging. There are two wires going into the connector, and there is a loop end connector on a third wire for ground.. but there's also a fourth wire coming out that has no end (taped up end actually), and it's not been hooked up at least since I've owned the car (Feb/March-ish).
Anyway, I went to go hook the negative terminal back to the battery. Upon doing so.. sparks.. and then nothing. No lights, no power to the car.. honestly haven't tried to start it yet, but no other power. Voltmeter on the battery says it's at 12.24-ish, if my memory serves me correctly. Checked the fuses under the hood.. the alt. fuse is fried.
Now, I'll replace the fuse.. but my question is.. why? What happened that friend the fuse? Is it that the ground isn't hooked up properly? (remember, it's on the furthest towards the driver's compartment of the two possibilities..) Anyone know what could have suddenly caused the fuse to be fried?
