ReebisTSI
- 38
- 1
- Oct 28, 2003
Ho-town,
Michigan
I was searching around the forums and really couldnt find a definitive answer so here goes:
The Problem:
Just got my EVO3 GT installed and was looking for 12lbs before i put my 190lph in. It spools right around 3k, and depending on my boost controller setting, spikes to what I assume is what the BC is set to and then immmedialty drops to 8-9 lbs....this leads me to beleive a boost leak
I have performed a boost leak test and have fixed all the ones I have found. I have noticed that there seems to be some pressure leaking from the PCV hose around the spring clip that secures the hose to the valve. Can the PCV be a boost leak spot? Also, I have notiuce that my 1g BOV is leaking a little bit when I pressurize to 15-20 lbs. Could this be my problem, or is it ok since I am recirculating?
Thanks for the help
-bob
The Problem:
Thanks for the help
-bob
