nycedsm
- Apr 11, 2006
Muskegon,
Michigan
I have a 95 eclipse gst FWD. I parked my car last fall because after a night of hard driving it wouldn't go in gear. I coasted home and let it sit over night. The next morning i started it and to my suprise it was making this weird grinding noise, almost like the bindix on the starter isn't coming off the flywheel. I still won't go into gear. Does anyone have any ideas about what this could be?
I also am having another problem with my starter. When i hit the key it clicks almost like its a bad sylanoid, but i have changed the starter in the past to try to solve the problem.if you hit the ket enough times the car will start. I recently saw a post on another forum saying he was having the same problem as me. The previous owner of my car replaced the master cylender. when he replaced it he tried adjusting the clutch rod. Would the adjustment have anything to do with any of my problems. and if so what is the proper adjustment for the master cylender.
I am also have a similir oil leak to another post on this forum. My guess was front main or balance shaft because of where the oil is. I guess my question is where are common oil leaks on 2g's
Thanks 4 you help
Jeff
Thanks 4 you help
Jeff
