spocks90talon
- 102
- Nov 2, 2004
dayton,
Ohio
ok i bought my 91 tsi awd about 2 months ago runs perfect, perfect compresson, no real problims till about 2 weeks ago i went to jump my buddys honda
and as i was about to leave i notice a fairly large oil spot under my car. ive been spending the last week or so trying to figure out where its leaking from but i cant pin point it.
heres the weird part...
i was doing some test to see, started the car up, it dry starts and was ticking pretty loudly (by the way it was not low on oil at the time,) i let it warm up all the way and as soon as the temp gauge reached the center(where it normally sits) the ticking stops, i jump out and rev it a little to see if it will tick again but it wont, i rev it some more this time i let it boost same deal no tick but i see a little bit of black smoke blowing out from under the exaust manifold, i look under the car and its very slowly dripping oil from under the drivebelts, i shut the car off and look under again and this time oil is dripping at a much higher rate from under the drive belts than when it was running. i stick my hand in the puddle to confirm that it is oil(which of course it is) but the oil is not even warm at all its actually about room temp, mind you this is like a minute after the car was running at normal temp for about 10-15 mins so the oil should be at least warm. this has me very confused my buddy said it might be the timing cover seal(or front main seal as he called it) or the oil pump but oil pressure is normal plus the whole dry starting thing my car never does that unless its real cold out and it wasnt low on oil either. it wasnt cold out, the car ran fine didnt blow any smoke out of the exaust even when under boost. i dont know what to do i dont want to take the timing cover off if i dont have to. if anyone has any ideas please let me know i dont wanna blow my motor!
and as i was about to leave i notice a fairly large oil spot under my car. ive been spending the last week or so trying to figure out where its leaking from but i cant pin point it.heres the weird part...
dont wanna blow that motor
i climbed under my car yesterday and had my buddy start it up and thats when i found that the oil pan is leaking from the side by the drivebelts, so a new 7 doller gasket and that should be fixed sooon thanks for the help anyways guys
